Will there be a discount on DT Pro for registered PE users? Seems like I recall this being mentioned once.
Thanks.
Thanks.
Yes. You can request a coupon for the discount.
Go to http://www.devon-technologies.com/shop/shop.php. Click on the link under the heading “Are you an upgrader?”
I’ve used DT for a while and downloaded the Pro version when it first came out. I never upgraded but Pro runs fine. Is it going to self-destruct at some point if I don’t upgrade?!! Usually there’s some sort of “this expires in 30 days” message with new software. Is the upgrade “voluntary”?
Your copy of DT Pro will eventually run out of demo time.
As a registered user of DT, you are eligible for an upgrade discount. You can request the upgrade coupon at http://www.devon-technologies.com/shop/shop.php, under the heading “Are you an upgrader?”
