I was wondering if label names and colors work in DTTG 2? All of my labels say “unnamed” and no matter which I choose it is always black. That changes when it is synced back to DTPO where the correct color label shows up.
I have not changed the default labels in DTPO at all.
I have the same appearance. The label is initially non-filled. When pressed it turns black. All fields in the list reads “Unnamed”.
A color IS attached to the DTTG2 item. When synched to DTPO it appears there.
The above applies to the iPad Air 2
I should also add that the labels work as expected on the iPhone 5S
Yes, label names are supposed to Sync if the option to Sync label names and colors is On. (It is by default.) I am not seeing the issue here.
Are you running DEVONthink 2.9.2 and DEVONthink To Go 2.0.1?
