I really like that I got gently warned about the subscription, but I thought I had somewhere seen that for DTTG2 people there is an upgrade path. The screen above doesn’t list this,
There is an upgrade path; it relies on DTTG3 being aware of DTTG2 being previously installed on your device. I thought that it was sufficient for DTTG3 ever to have been opened when DTTG2 was still on the device. I may be mistaken, or maybe that just wasn’t the case in your case. Anyhow, if you put DTTG2 on your device (you will need to download it from your purchases rather than directly from the AppStore) and then open DTTG3 (you may either need to restart the iOS device, or open DTTG2 once first; perhaps you could post back here whether you had to do either of those things), you should be offered the lower one-time purchase price.
Yes, DEVONthink To Go 2.7.8 or 2.7.9 needed to be installed on the device at least once when you opened DEVONthink To Go 3. Version 3 then made a “mental note” of the presence of version 2. Maybe you removed version 2 already prior to installing version 3? In this case DEVONthink To Go 3 has no way of knowing that you’re an upgrader.
You can reinstall version 2 from your purchases in the App Store app to let DEVONthink To Go 3 know that you’re eligible. It will then offer you the discounted upgrade.
No. Still stuck at the screen asking to up upgrade or pay. Retry/Restore does not do anything. V2 seems OK with the Pro Package marked as Purchased. V3 does see the reduced rate upgrade by the way.
Maybe on your iPad you used the sandbox account in iOS’ Settings > App Store to “pay” and on the iPhone you don’t? Sandbox “purchases” don’t carry over.
