I am using the smart rule to add metadata to academic articles with the download bibliographic metadata copy smart rule. This had been working well for the past week, but today I am getting error
“The variable json_record is not defined.”
Appreciate any help as to what is going on. Nothing was changed in my setup, and I am not comfortable with writing script so just using the built in scripts.
It’s a bit difficult to comment on an error in a rule or script without seeing said rule or script. And searching in the forum for DOI smart rule returns too many hits …
Probably http://dx.doi.org/ does not return a value for the DOI, so that json_record is not set (and the script doesn’t check for that). Yes, a copy of the document in question would definitely help.
I can provide copies of documents if you like, however this script worked fine up until yesterday (worked when I transitioned my entire Zotero database over). When it stopped yesterday I went back to previous source files and tried and I get the error now on every file, even the source pdf ones that were already successfully identified so I’m not sure the issue.
Edit: I’m not sure I can actually upload a pdf of articles since they are behind paywall, but I have included an article I just tried that appears free to download that I also get the same error.
Just did a test on my iMac (I have only used DT from MacBook but downloaded and thought maybe try from iMAc) and the script runs no issues. Not a network issue.
So at least we know that it’s not the script that is at fault here.
Do you see anything in DT’s log window on the iMac? Has anything on the iMac changed after yesterday, i.e. from when the script worked and when it stopped working? Oh, and are you perhaps running MacOS Ventura?
Not running the beta. Same os on both (up to date current macOS). Same network. Devon think was installed on the working iMac 3 days ago as compared to a few weeks ago on laptop.
The only thing the log says is the json_record error on every file.
If no other ideas I’m considering deleting and reinstalling the app tonight after work. Not sure what else to do
I’ll append a very slightly modified version of the script. Open it in Script Editor (with the button underneath the code listing), turn on its protocol (Cmd-3), select one of the offending records in DT and then run the script in Script Editor.
Check the “Events” and “Answers” tabs in the Script Editor’s protocol pane at the bottom.
-- Download Bibliographic Metadata
-- (c) Kai Müller May 05, 2019
-- Renamed, simplified, enhanced and updated for smart rules by Christian Grunenberg
-- 1. Retrieves the digital object identifier (DOI) of the document
-- 2. Downloads bibliographic metadata, renames document to title and sets DOI, ISSN, Link, Date, Journal, Volume, Issue, Publisher, Type, Authors and Citation
-- NOTE: Every downloaded PDF publication (e.g. from Google Scholar or any Journal) might work.
--on performSmartRule(theRecords)
show progress indicator "Downloading Bibliographic Metadata" steps (count of theRecords) without cancel button
step progress indicator theName
set customMetaData to custom meta data of theRecord
set doi to mddoi of customMetaData
if doi begins with "http://dx.doi.org/" then
set doi to (characters 19 thru -1 of doi) as string
else if doi begins with "https://dx.doi.org/" then
set doi to (characters 20 thru -1 of doi) as string
on error
set doi to ""
set doi to digital object identifier of theRecord
if doi is missing value then error
on error
set doi to ""
if doi is not "" then
add custom meta data doi for "doi" to theRecord
set the doi to "http://dx.doi.org/" & doi
set the json_record to download JSON from doi
set theRecord's name to (title of json_record) as string
set the json_created to created of json_record
add custom meta data |date-time| of json_created for "date" to theRecord
if exists (|published-print| of json_record) then
set pubyear to item 1 of item 1 of |date-parts| of |published-print| of json_record
else
set pubyear to item 1 of item 1 of |date-parts| of |published-online| of json_record
set the authors to author of json_record
set the citation to ""
set cnt to count of authors
if cnt < 3 then
repeat with i from 1 to cnt
set author to item i of authors
if i > 1 then
set citation to citation & " & " & family of author
else
set citation to citation & family of author
else if cnt > 0 then
set author to item 1 of authors
set citation to family of author & " et al."
add custom meta data (citation & " " & pubyear) for "citation" to theRecord
set the authorsList to ""
repeat with author in authors
set authorsList to authorsList & |given| of author
set authorsList to authorsList & " " & family of author & return -- return ensures that DEVONthink automatically defines this field as text and not as a string
add custom meta data authorsList for "authors" to theRecord
set the articletype to |type| of json_record
add custom meta data articletype for "type" to theRecord
set the link to |URL| of json_record
add custom meta data link for "link" to theRecord
set the publisher to publisher of json_record
add custom meta data publisher for "publisher" to theRecord
set the issn to item 1 of issn of json_record
add custom meta data issn for "is?n" to theRecord
set the journal to |container-title| of json_record
add custom meta data journal for "journal" to theRecord
set the volume to volume of json_record
add custom meta data volume for "volume" to theRecord
set the issue to issue of json_record
add custom meta data issue for "issue" to theRecord
set the page to page of json_record
add custom meta data page for "page" to theRecord
log message record theRecord info error_message
hide progress indicator
--end performSmartRule
