This creates a text file on your desktop so we can see what DEVONthink gets as input. Run it on the same selection that threw the error
-- Open selected text's link(s) in default app
property theDelay : 0.5
delay theDelay
tell application "System Events" to tell (first process whose frontmost is true) to keystroke "c" using {command down}
set theGrepResults to do shell script "osascript -e 'the clipboard as «class RTF »' | perl -ne 'print chr foreach unpack(\"C*\",pack(\"H*\",substr($_,11,-3)))' | egrep -o 'x-devonthink-item[^\"]*'" -- https://superuser.com/a/1409995/
on error
display alert "No text selected or no link(s) found" buttons {"Ok"} default button 1 message "" as critical
return
set theRefURLs to paragraphs of theGrepResults
repeat with thisRefURL in theRefURLs
my write_to_file(thisRefURL & linefeed, (POSIX path of (path to desktop) & "Script Debugging.txt") as string, true)
on write_to_file(this_data, target_file, append_data) -- (string, file path as string, boolean)
set the target_file to the target_file as text
set the open_target_file to ¬
open for access POSIX file target_file with write permission
if append_data is false then ¬
set eof of the open_target_file to 0
write this_data as «class utf8» to the open_target_file starting at eof
close access the open_target_file
return true
on error
close access POSIX file target_file
return false
end write_to_file
I think I understand the problem. In my links, the label and the target are both things like:
x-devonthink-item://D410B352-231E-47E8-82BB-73DECA3E545F , and that doesn’t seem to work.
I know that that’s the problem because if I change the label in the above link to be just some random text then it seems to work. So I either need to rewrite the code that generates the links so it gives them some safer label… or perhaps there’s a way to tell the script to look at the target, not the label.
Here is the script. Added an option to have the first link as front window instead of the last.
property reverseOrder : true
delay theDelay
on error
return
if reverseOrder = true then
set theRefURLs_reverse to {}
set beginning of theRefURLs_reverse to thisRefURL
set theRefURLs to theRefURLs_reverse
if length of (thisRefURL as string) = 56 then
set thisUUID to (characters 21 thru -1 in thisRefURL) as string
set thisRecord to get record with uuid thisUUID
set thisPath to path of thisRecord
tell application "Finder" to open file (POSIX file thisPath as alias)
Perfect! Thank you thank you for your willingness to spend time on this!! And having the script search a whole selection for links is the perfect example of a user not realizing what they need until it’s shown to them. Great design.
Carl
btw: one of my students is doing a project to predict the places most at risk for future covid outbreaks. So your efforts will help him move forward a little more efficiently. Every bit helps.
