Hi,
are there plans for the sidebar to allow double-click for expanding and collapsing ?
I use a high screen resolution and small fonts and it’s hard to handle only with the symbols when you do a lot of navigating.
Andreas
Hi,
Andreas
Expanding and collapsing databases is already supported in the Open Databases section of the Navigate sidebar.
It’s not supported in the Globals section, but Development would have to assess that.
Version 3.0.1 will improve this.
Do you mean this will be improved for the the globals section or that even the folder structure of a database can be double clicked too ?
Both. But in case of groups only if the preference to open new windows after double-clicking on groups is disabled.
