Development would have to comment on it, but it could be an underlying migration mechanism in DEVONthink 3.
No, DEVONthink doesn’t move scripts around. Version 3 has always installed & updated them in the same location (~/Library/Application Scripts/com.devon-technologies.think3) since the first public beta. Were any of the toolbar scripts downloaded from the support assistant?
Not sure exactly what this means. I downloaded them all from here (Discourses). Two I used sporadically and they were basically unchanged, two others I changed to fit my specific purposes and still use them daily.
Since all this only happens when I start DT via the browser extension, I would say evidence points there. I’m not starting DT that way anymore, only via Dock.
Also, this might have something to do with my M1 macbook?
I could finally reproduce this, the next release will fix it.
Yeeeehhhhahhhhh!
Mine disappeared again, even though I knew they were in ~/Library/Application Scripts/com.devon-technologies.think3/Toolbar
This time they didn’t reappear after re-launching DT3, and I’m not sure how to get them back! Edit: seems I have to re-drag them back from the toolbar’s customisation pane.
But I see that @cgrunenberg seems to see the problem.
