Hello!
I am using DEVONthink 3.5.1
on macOS 10.15.5
(Catalina).
The sorter (I use it from the menu bar) clips the dropdown selection control on the location
field whenever I use the web clipper extension from Firefox (77.0.1
). The control works fine (I can click it anywhere in the control and the dropdown does appear).
However, I can get the control widget back if I select another section in the sorter (_for example, the Take Note
and then back to Web Clip
). Hence this is not a show-stopper, but more of a visual glitch.
I have attached a couple of screenshots (before and after), which probably explains this better.
