I setup a smart rule to OCR whatever is scanned and saved by my network scanner into an index group. My OCR preference “Move to Trash” is enabled. This setup is working normally in DT3b1.
I was just about to post this bug - the new OCR file appears in the Global Inbox, but is deleted from the indexed folder.
Also, there is an error with the OCR: the file was a single page of text in landscape, but not identified as such, and Abby Reader has (correctly) flipped the image, but cropped out content.Waleys 16-22-01-008.pdf (328.8 KB)
The main issue is that the OCRed file is automatically moved to the global inbox by the same smart rule under DT3b2 (which it shouldn’t), that’s why the original group is left with a missing file.
While this is being assessed, is there any way to move the newly created item back to where it came from? I’m trying to “Move” the new files back to the databases from which they’ve come, but I can’t figure out how to identify that (unless I create a smart rule for each database, and then run those separately). Thanks.
OCR wasn’t available as a direct option. Selecting a webarchive directly, and right-clicking and selecting “OCR->” from the menu shows only grayed-out options.
Right clicking it and “convert-> to PDF” (which I hadn’t tried before) in fact creates a new PDF+Text item. (So, the original issue with OCR in 3b2 moving items to the global inbox, which still happens, no longer needs to be solved for this particular rule).
So, I suppose 1) I don’t need to OCR webarchive files, merely apply a rule that converts webarchives to PDF+Text, but now I’m trying to figure out how to 2) set the Date Created and Date Modified back to those of the original document, and 3) move the webarchive to trash.
It’s also possible to use the Execute Script > Embedded(only using embedded for convenience here) with this code…
create PDF document from (URL of theRecord as string) in (current group) without pagination
end performSmartRule
