property pTitle : "DEVONthink Pro Batch Rename"
set sourcePattern to display name editor pTitle info "Source pattern:"
set destPattern to display name editor pTitle info "Destination pattern:"
if sourcePattern is not "" and destPattern is not "" then
set selectedItems to selection
repeat with selectedItem in selectedItems
set itemName to name of selectedItem
set transformedName to do shell script "echo " & quoted form of itemName & " | sed -E 's/" & sourcePattern & "/" & destPattern & "/g'"
set name of selectedItem to transformedName
Surely there’s a nicer way to do it, but deleting and destPattern is not “” allows it to accept ‘’ (two single quotes) as an empty destination pattern so it’s usable for removing unwanted text from item names.
I’m satisfied using this instead of the less capable Rename using RegEx script.
