Hi,
I have a massive problem with DTPO 1.3b2.
I´m not able to start it. When I click the Dock Icon, the starting window opens, the progress bar starts, but stops in the first half, (in the mode “intiliaze&check” (german: initialisieren und überprüfen), also the twinning coloured ball dissappears …
The prehistory: Everthing works fine, until I decided to try to download my Weblog with all the documents I have linked to on other sites (Call me crazy …)
This takes some hours, and in the end I had an archive with 25.000 files in my DTPO database.
I decided to delete it. I try to delete this archive in a whole by pressing the delete-icon. But after a while DTPO crashed.
I started again, everything was fine. I try to delete it in parts, which works most of the time. Sometimes it crashed and I found, that was because of specific files.
So, I try to avoid this files during the deleting process firstly (although I cannot say which ones exactly).
In the end I had some groups, one with more than 2300 files and another one with 450 file, and I tried to delete the last one, but then it crashed, again.
I tried to restart, but then it happend what I described in the beggining. I restarted the whole computer (iMac G4, 1,25 Hz, 1,25 GB RAM, MacOS X 10.4.8 ) but wih DTPO it was the same result.
I download DTPO 1.3b2 agin from your website and install it. Than tried to start it, and once again: it stopped in the initialize&check phase.
What can I do?
Until now I´m a very satisfied userm but I think I reached the borders of the system …
