Hi,
I’m using labels on files to have easy access to them on the go, but the labeled files show up in a very random sequence. I’d like to have them sorted, inside the labeled smart group, by label. It is a bit too much friction when I have to look through the entire stack of files to find the ones with the right label. The app doesn’t give me options regarding sorting of files inside the smart group that I can see.
Keen to hear your thoughts on this.
