Hello!
While most metadatas and properties are now ported to DTTG4, there’s one I use and that seems missing: tag/group icon color.
Thanks to consider having that one as well in DTTG4, so that color-codings applied to DTP4 appear in GTTD4.
Hello!
Are you referring to this?
Almost, in DTP4, you can change a group/tag/grouptag icon, or you can apply an extra color it. I refer to the later, which seems absent of DTTG4.
That’s correct. The color is currently synchronized in a Mac-only data format.
Adding an image by dragging and dropping over the folder/file symbol syncs over to iOS…
More customisable than just colours…
