Hej
Is there any easy way (from within the DEVONthink GUI abd not by copying the contents of the ~/Library/Application Support/DEVONthink 3/Templates.noindex directory) to export all or all the custom made templates?
Thanks
Hej
Thanks
Sorry but no, there isn’t a GUI option for this.
Open the templates directory and move the templates wherever you want
That was not the question. I think @BLUEFROG understood the question correctly.
The only idea I have is that you could add a script which performs the necessary actions to the toolbar. That way you could perform the export from the GUI. Whether it’s worth it to you to script that action would, of course, be very much up to you
Note: We do have an item on our never-ending list of potential future enhancements for syncing resources between Macs, but nothing concrete at this time.
