Empty Trash Problem
I have an annoying little problem with the ‘Empty Trash’ command in DTPO. What his happening, or rather not happening, is that whenever I empty the trash this one item does not move to my Trash Can—anything else will go but this item stubbonly refuses to be deleted. Any ideas how to get rid of this?
The file is locked-look at the padlock on the right pane of the image that you posted. You can toggle the lock status from DEVONthink’s Info panel.
Thank you Greg, easy when you know how! :blush:
The Iconology section of the Appendix in DEVONthink’s Help documentation shows icons, with their meanings, that appear behind item names.
