Encountering ongoing MAJOR crashes for a few days
UPDATE: it appears one of the ways to create a crash is to try to save particular documents. Every single time I hit cmd-s on those documents, DT crashes. Does that mean corrupted files/metadata? Any way to check this?
For a few days, DT pro Office is continually crashing. It keeps closing by itself at some point. Sometimes right after launch. sometimes after clicking on a document. Sometimes saving a document makes it crash (and lose my data)
Nothing changed on my Mac recently. I ran a bunch of tests, everything seems fine.
crash report from Apple below
Process: DEVONthink Pro [450]
Path: /Applications/DEVONthink Pro Office.app/Contents/MacOS/DEVONthink Pro
Identifier: com.devon-technologies.thinkpro2
Version: 2.3.1.1 (2.3.1.1)
Code Type: X86 (Native)
Parent Process: launchd [263]
Date/Time: 2012-06-01 14:38:01.632 -0400
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 1651 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 3638 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: AF54035D-1DAA-4A94-B05E-4158B9F74F9E
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: Unknown
Backtrace not available
Unknown thread crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x92169693 ecx: 0xbfffe56c edx: 0x920c0c5a
edi: 0x0000024c esi: 0x00783af7 ebp: 0xbfffe588 esp: 0xbfffe56c
ss: 0x00000023 efl: 0x00000282 eip: 0x920c0c5a cs: 0x0000000b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00715300
Binary images description not available
Model: iMac12,2, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.7 GHz, 8 GB, SMC 1.72f5
Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 512 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.35.3
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST31000528AS, 931.51 GB
Serial ATA Device: HL-DT-STDVDRW GA32N
USB Device: FaceTime HD Camera (Built-in), 0x05ac (Apple Inc.), 0x850b, 0xfa200000 / 3
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: iPhone, 0x05ac (Apple Inc.), 0x1294, 0xfa120000 / 5
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0xfa111000 / 6
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfd110000 / 4
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000 / 3
Please verify your database(s) (see Tools > Verify & Repair). If there should be no errors, then please check whether updating to the latest release (2.3.5) will fix this issue.
If not, could you please send us all crash logs from ~/Library/Logs/DiagnosticReports and check whether anything has been logged to the system console (see /Applications/Utilities/Console.app) right before the crash? Thanks in advance!
