Encrypting sync stores and encryption in general:
I set up DT database on a Mac and DT client on my iPhone. I don’t remember if I chose to encrypt the sync store. How do I find out if I did or not, and if not, can I add encryption now or need to start over?
Also, “Encrypted Databases” - how does that work? I saw it mentioned at DEVONtechnologies | How to Keep Your Data Private - once I use Disk Utility to create an encrypted file, then what?
There is a property icon next to the sync store in DEVONthink’s Preferences > Sync and is shown in the illustration in the blog post you referred to.
No, you can’t just add encryption. This is covered in the In & Out > Sync > Basics and How To section of the built-in Help and manual
You don’t need to use Disk Utility for this purpose as DEVONthink can make its own encrypted databases. See Getting Started > Building Your Database in the manual or Help >Tutorials > Use Encryption.
The property icon is a little key symbol, right - on the server side (DT3 running on my Mac), and if it’s there, it’s encrypted?
The key indicates an encryption key has been set, regardless if it’s a local or remote sync method.
