Have lots of .zip files in my DevonThink Pro (1.2) database. When I drag for example a zipped file from my database to the desktop it changes the extention name.
So ao_ibl_local_v03.zip changes into ao_ibl_local_v03.dtLink
So have to manually drag the file to stuffit expander. Can’t just double click on the file because nothing happens. Macos X 10.4.7 doesn’t reqocnise the extention .dtLink I guess.
Bob, it seems that the .zip files are not actually imported to your DT database, but only indexed, i.e., DT does not hold the actual file but only a reference to it – the .dtLink file you get when you export it.
Thanks for your response. What compression method do you advice I should use maybee stuffit? I need a complete compressed file that I can drag out off Devon Think pro so all the files are in it they way it was compressed.
Whatever compression format you want. Just make sure that the files are correctly imported. Check “Unknown files” on the Import tab to let DT import even those files it does not know of, e.g., compressed files.
Files that are only linked within DEVONthink show a zigzag arrow behind their name.
Ah, you are using DEVONthink Pro 1.2, right? That’s a bug already fixed in my beta here. File > Export > As Files and Folders should work until we ship DEVONthink Pro 1.2.1.
