Is the focus color changeable. When focused on a group in the database left panel it is hard to read.
It’s the system-wide selection color. Which macOS version do you use?
Actually now it changed only the sub groups have the problem.
I was switching between full screen mode and back and that might have caused the change.
I’m not seeing this issue on 12.6.
On a side note: The accent color will only apply when Preferences > General > Interface > Sidebar: Keyboard Navigation is enabled. Is this expected, @cgrunenberg?
Yes.
