For anyone thinking of diving into Catalina, be aware that doing so will prevent the DT mail plug-ins from working. This is by (Apple) design. The DT team will, I’m sure, have them working for the 10.15 release - but we can’t reasonably expect them to issue changes for a beta that will change radically between now and release.
This is, of course, on. top of the WARNING not use a Mac OS beta on critical systems. Not that anyone wise enough to use DT would be that reckless
A reinstallation of the Mail plugin might be sufficient but in case of any internal Apple Mail changes or additional barriers more work might be necessary. In the meantime at least the scripts should work.
Reinstallation doesn’t work. The files are there in the Bundles folder but Mail/Preferences/General/Manage Plug-ins presents an empty window, so the plug-in can’t be activated. I’ve tried delete/reinstall, check permissions and so on
It may be a bug in Catalina - there’s all kinds of weirdness with permissions and file locations.
Could you please create a sample first? Just launch Apple’s Activity Monitor application (see Applications > Utilities), choose DEVONthink 3 in the list of processes, select the menu item View > Sample Process while DEVONthink 3 is frozen and send the result to cgrunenberg - at - devon-technologies.com? Thanks in advance!
There are some significant issues with iCloud Drive in this beta of Catalina. The sync process (between the cloud and the Mac local storage) does not appear to work properly. As a result, files are not downloading to local storage and thus can’t be acted on by applications or services.
BTW, my MacBook Pro is blowing like hell and TG Pro is complaining about more than 100 CPU degrees. Clouddd, photoanalysisd and other iCloud related stuff are using ALL CPU…
