Hi, On the DEVONagent Express Mac Menu Bar the default search engine appears to be Google with no way to change it. Does anyone know if it is possible to change this? I’m trying to de-Google my machine! Thanks.
Welcome @Mr_Ed
Click the magnifying glass to change the search engine. DEVONagent Express should remember this choice between launches.
Thank you!
You’re welcome!
Thank you!
