Group within current group
Is there a way to reference a group within the currently selected group?
I have used this here
set theGroup to create location "/z PROJECTS DONE"
to reference groups within the currently selected database.
So how’d I reference a group that is in the currently selected (deeply nested) group?
Not sure where you’ve selected the group, whether in the Navigation Sidebar or in the Item List.
		#-- Window root
		#set theGroup to root of viewer window 1
		#-- Current group
		#set theGroup to current group
		-- Selected record
		if theRecords = {} then error "Please select a group in the item list."
		if (type of (item 1 of theRecords) as string) is in {"group", "«constant DTgr»"} then
			set theGroup to item 1 of theRecords
			set theGroup_Name to name of theGroup
			if theGroup_Name contains "/" then set theGroup_Name to my escapeSlash(theGroup_Name)
			set theGroup_LocationAndName to (location of theGroup) & theGroup_Name
			set X to create location theGroup_LocationAndName & "/" & "Test"
		else
		return
on escapeSlash(theText)
	set AppleScript's text item delimiters to "/"
	set theTextItems to every text item of theText
	set AppleScript's text item delimiters to "\\/"
	set theText_escaped to theTextItems as string
	return theText_escaped
end escapeSlash
