Dear DT,
in Files ➞ Markdown ➞ Import images to group I seem not to be able to import images in my previously created Group “DOC”.
Instead, all images go to a DT newly created group “DOC x-DEVONthink-item”.
What am I doing wrong?
Please, see attached screenshots.
Thank you so much, also for your beautiful software (loyal customer since 13/03/2004)
Ubaldo
Thanks for the kind words and longstanding support!
What smart rules are you running?
hi @BLUEFROG please see attachment.
Is it possible that the Import images to group… text field contains more than the just visible /DOC
Hy @cgrunenberg
no, text field contains only /DOC.
Furthermore, if I set text field to /ASSETS I get /ASSETS x devonthinkitems: in MyWiki Groups…
Please enter this command in the Terminal.app:
defaults read com.devon-technologies.think ImageDestination
What does it return?
There’s indeed more in the text field and that’s causing the issue. Just press Cmd-A in the text field, then backspace and finally enter the desired destination.
Aaaaghhhh
You are right. Everything OK now. Thank you
Ubaldo
