Help getting started using DevonThink built-in AI?
I’ve read the blog post and the built-in help, and I’m still rather at a loss. Why would I want to use DEVONthink’s built-in AI rather than go to the Web and, if necessary, upload documents to our chatbot of choice?
One obvious answer is that using DEVONthink eliminates the need to upload anything, and that would indeed be a benefit. And I tried it just now, asking a question of a relatively short PDF. The progress indicator spun for a few minutes and then I got an error message as follows:
You exceeded your current quota, please check your plan and billing details. For more information on this error, read the docs: https://platform.openai.com/docs/guides/error-codes/api-errors.
I zapped by DEVONthink ChatGPT API key from ChatGPT, created a new one, and entered it in DEVONthink. Same error.
Also, when I typed in my question, I see the following — note the "7 hours ago* time indicator, which appears immediately when I hit send.
Additionally, I have no idea which model to use. The models listed in the dropdown in DEVONthink don’t match any listings I see on the web.
So all in all I’m struggling here! Please help!
I’m going back to the help document — maybe I missed something.
Never mind.
Ok, I got it working on a couple of queries. It’s very slick. It’s like NotebookLLM but it lives on your desk.
Can you please describe what you did, so others can learn from your experience? Thanks!
E.g. because the chat assistant is able to…
  • search your database
  • search the web, Wikipedia or PubMed on its own, even when using local models like Gemma 3
  • download links (e.g. of web pages or even item links) to retrieve additional information
  • optionally change properties (e.g. tags) and contents
  • process annotations of PDF, RTF(D) and Markdown documents, e.g. summarize them
  • return item links (e.g. links to sections/pages in Markdown, EPUB or PDF documents), e.g. in a summary or table depending on your prompt
  • use multiple models from various providers in one chat
  • handle also third-party document formats that were indexed using Spotlight’s plug-ins
In addition, contrary to uploading documents in the chat app of your choice, DEVONthink performs various steps to increase the security & privacy. See DT4 - privacy when using AI - #6 by cgrunenberg
And of course it’s much more convenient than switching apps and uploading documents :wink:
What’s your time zone?
Briefly: Some time ago, I entered my credit card number into ChatGPT to use its API with applications.
Some time later, I entered my ChatGPT API key into DEVONthink.
This week, when I tried this query, I was confused about the error about rate-limiting, because I was sure I had set a rate limit of $20 or $25/mo or so. I had not done any queries previously. And the ChatGPT billing page was showing my usage as zero.
After doing research into how ChatGPT API billing works, I discovered that it’s not enough to give them a credit card number. A user must also “charge” their account with a certain amount. It’s like buying tokens at an arcade or using a prepaid phone — you have to give your money to OpenAI before you can use the service.
Incidentally, I also changed the credit card I was using. That had nothing to do with my troubleshooting; my wife and I no longer want to use that particular credit card for my business expenses.
As is often the case when troubleshooting tech problems, I did not take notes as I went, and I cannot guarantee which step or steps fixed the problem.
(I mentioned my lackadaisical record-keeping to friends who are professional software developers, along with one who previously had a long career working fix-break for a corporate IT department. "I’m sure that you, professionals at this kind of thing, keep detailed records of your troubleshooting attempts. They looked embarrassed and said, "Ummmm… " So I feel better about my own lackadaisical habits — and now I have this record, which will hopefully help me and others should this problem recur.)
