Hi,
i am trying to take a .csv file that I exported from Excel and use one of the columns as the “Comment” on each of the files. Basically, the .csv is the index of the files in a folder in DTPro and has a field for my reviewer comments. I would like to integrate those comments into DTPro as the comments on the files themselves rather than the index. Seems simple enough, as I just have to tick down the csv file copy each entry at that column, set it to the comment, and go down each in sequence. I am having trouble though.
thanks christian,
I got the sheets part to work. Now, what is the best way to go to the record/pdf that i want to slap the comment into? Let’s say it is in a group called “Pdfs” and has a name that also can be pulled from the sheet.
is there a way to say set comment of record with name equal to " " to comment
There are several ways to find a record, here are two examples:
set theName to "Test"
-- Throws an exception if content does not exist
set theRecord to content named theName of current database
-- Searches only inside the specified group
set theGroupLocation to "/PDFs/"
set theRecord to get record at (theGroupLocation & theName)
