I have been working on a script (see below) to get Microsoft Word to split a large RTF file into smaller files (splitting the document where it finds a date). Everything works fine except that I would like the RTF files created to fit to the width of the view/window in DT, as happens when you create new RTF files in DT. At present the RTF files have a fixed width which doesn’t fill the space. I am aware that I could manually drag the right margin tab in the view to the right edge in DT to make the text fit the view, but because we are talking about a very large number of RTFs I would rather avoid this.
Ideally there would be a way to script MS Word to change the formatting of the RTF files before saving, but I have not found a way to do so, and it may not be possible.
So then I wondered whether it would be possible to adapt the script so that the new RTFs are created directly in DT, i.e. each section of text identified in the script is copied to the clipboard and a new RTF file is created in DT from the clipboard. Hopefully this way the RTF files would have the formatting I would like.
But I am open to any suggestions from those who are more in the know.
Thanks
Nick
property monthNameList : "JanFebMarAprMayJunJulAugSepOctNovDec"
property isEmptyLineAfterDateLine : true
property destinationFolder : missing value
set sourceFile to choose file
set newDocCount to 0
tell application "Microsoft Word"
open sourceFile
set aDoc to active document
set docName to name of aDoc
set numberOfParagraphs to count paragraphs of aDoc
if docName ends with ".rtf" then set docName to text 1 thru -5 of docName
set destinationFolder to ((path to desktop as text) & docName)
do shell script "/bin/mkdir -p " & quoted form of POSIX path of destinationFolder
repeat with i from 1 to numberOfParagraphs
tell application "Microsoft Word" to set textValue to content of text object of paragraph i of aDoc
set {dy, mn, yr} to checkDate(textValue)
if dy is not false then
if newDocCount is not 0 then
makeNewDocument(aDoc, low, i - 1, fileName)
set low to i + 1 + (isEmptyLineAfterDateLine as integer)
set newDocCount to newDocCount + 1
set fileName to yr & "-" & mn & "-" & dy & ".rtf"
else if dy is false and i = numberOfParagraphs then
makeNewDocument(aDoc, low, i, fileName)
on makeNewDocument(aDoc, fromParagraph, toParagraph, fName)
set myRange to create range aDoc start (start of content of ¬
text object of paragraph fromParagraph of aDoc) end (end of content ¬
of text object of paragraph toParagraph of aDoc)
select myRange
copy object selection
set newDoc to make new document
paste object text object of newDoc
save as newDoc file name (destinationFolder & ":" & fName) file format format rtf
close front document
end makeNewDocument
on checkDate(theString)
set {TID, text item delimiters} to {text item delimiters, space}
set {dy, mn, yr} to text items of theString
if (count mn) < 3 or (count yr) < 4 then error
dy as integer
set dy to text -2 thru -1 of ("0" & dy)
on error
error
set monthOffset to offset of (text 1 thru 3 of mn) in monthNameList
if monthOffset = 0 then
error
else
set mn to text -2 thru -1 of ("0" & (monthOffset div 3) + 1)
if (count yr) > 4 then set yr to text 1 thru 4 of yr
yr as integer
set text item delimiters to TID
return {dy, mn, yr}
on error
return {false, false, false}
end checkDate
I don’t have Word, but you might want to cosy up to “attribute runs” in Applescript:
get properties of every attribute run of rich text of content 1 of database 1
There are only a limited number of RTF attributes that Apple/DTPO supports, and they are:
alignment
background color
baseline offset
class
color
first line head indent
font
head indent
line spacing
maximum line height
minimum line height
paragraph spacing
properties (ie all of these in record format)
size
superscript
tail indent
text
underlined
URL
You probably want to look at the “indent” properties, which I believe control the margins.
You might have better luck if you open your DOC files in TextEdit and manipulate them from there, and I’d look at Matt Neuberg’s book on Applescript for advice on dealing with RTF scripting.
It turns out that you can get the text to flow to fit the width by passing through an HTML phase, and then converting back to RTF.
property pstrTempFile : "tmp.rtf"
if not DT2Running() then
display dialog "Start DT2"
return
set oDoc to active document
set refParas to a reference to paragraphs of oDoc
set lstText to text object of refParas
set lngParas to length of lstText
if lngParas < 1 then return
set strDocName to name of oDoc
set {oGroup, oWin} to my GetGroupWin()
if (count of parents of oGroup) is 0 then
set oLocn to (create location strDocName in database of oGroup)
else
set oLocn to (create location (location of oGroup & "/" & name of oGroup & "/" & strDocName) in database of oGroup)
tell application "Finder"
set strTempFolder to (container of (path to me)) as string
set strTempFile to strTempFolder & pstrTempFile
set oFile to strTempFile as file specification
set strPosixPath to POSIX path of strTempFile
repeat with iPara from 1 to lngParas
set oText to item iPara of lstText
copy object oText
set dataRTF to the clipboard as «class RTF »
-- set the clipboard to dataRTF
-- set strRTF to (do shell script "pbpaste -Prefer rtf")
-- WRITE THE RTF OUT TO A TEMPORARY FILE
open for access oFile with write permission
write dataRTF to oFile as «class RTF »
close access oFile
-- USE TEXTUTIL TO GET AN HTML VERSION OF THE RTF
-- (HTML can be easier to read and transform,
-- and TEXTUTIL can be used again later to convert from HTML back to RTF)
set strHTML to do shell script "textutil -convert html -stdout " & strPosixPath
set oHTML to create record with {type:html, source:strHTML} in oLocn
set oNewRec to convert record oHTML to rich
delete record oHTML
set name of oNewRec to "Para " & iPara as string
on DT2Running()
tell application id "com.apple.systemevents"
(count of (processes where creator type = "DNtp")) > 0
end DT2Running
on GetGroupWin()
-- CURRENT GROUP, IF THERE IS ONE
set oGroup to missing value
with timeout of 1 second
set oGroup to current group
end timeout
-- ELSE CURRENT DATABASE, IF THERE IS ONE
oGroup
on error
set oGroup to (root of database id 1)
set oWin to open window for record oGroup
return {oGroup, oWin}
if oGroup is missing value then
-- ENSURE THAT A WINDOW IS OPEN FOR THIS GROUP
set {oDb, strID} to {database, id} of oGroup
set lstWins to viewer windows where id of its root is strID and name of its root is name of oDb
if length of lstWins < 1 then
else
set oWin to first item of lstWins
{oGroup, oWin}
end GetGroupWin
Simply converting an existing RTF record to HTML and back again will achieve the same thing (eliminating the right hand margin, and setting the text to flow to fit).
-- Assuming an existing RTF Record in DT 2 ...
set oHTMLRec to convert record oRTFRec to html
set oNewRec to convert record oHTMLRec to rich
delete record oRTFRec
delete record oHTMLRec
I amended your conversion script to work on a bunch of RTFs in DT. The script also changes the font to Optima 18.
Works a treat
set these_items to the selection
if these_items is {} then error "Please select some contents."
repeat with this_item in these_items
set theDate to the modification date of this_item
set Name_Rec to name of this_item
set oHTMLRec to convert record this_item to html
delete record this_item
set name of oNewRec to Name_Rec
set theWin to open window for record oNewRec
tell text of theWin to set {font, size} to {"Optima", 18}
close theWin with saving
set the modification date of oNewRec to theDate
