Help! Sorter disappearing.
I am not able to take notes with either the sorter “take note hotkey” or the compose note icon from the sorter itself. after hitting the hotkey, the sorter expands for a moment and then goes missing. if i click on the compose button in the sorter, it goes into hiding again. I have to quit and show from the settings of the DTPO to vies te sorter again. Take note from the “Tools” menu works fine.
Please help!
Does ths persist after a machine reboot?
Yes. I even removed and reinstalled DTPO. I think it happened after I was trying to stretch the sorter horizontally to the entire screen.
Maybe one these solutions helps:
url=https://discourse.devontechnologies.com/t/quick-sorter-panel-disappeared-from-desktop/14206/1[/url]
Thanks berndm. First one fixed the issue.
