Hi,
I’m trying to do a specific smart group, but so far I have no luck. The parameters are as following:
Last Created in 6 hours OR Last Modified in 6 hours
AND
Kind is not Group OR Smart Group OR Tag OR Feed
Anyone can help me?
Hi,
AND
Anyone can help me?
Post a screen capture.
My problem is that I want the results to both include the date created or the date modified, and to set the timeframe to the last 6 hours.
You can’t set criteria to hours unless you were referring to a specific date. This hour, Last hour, and Today are the closest possibilites.
And the OR situation (created OR modified) is also a dead end, I’m guessing.
Nope.
Using Any for criteria is an OR search.
Option-Click on the plus sign. That permits you to build sub-conditions with “any” or “all” as a predicate.
That’s it! Thanks.
