Did you read the Help > Documentation > Documents > Markdown Documents?
Hi @BLUEFROG,
Yes, I read this. It really was not that helpful. I think part of my problem was understanding what transclusion was supposed to be and do. I have since got it to work, but it was not what I expected. I thought I could mouse over the link and see a popup of the material.
I think I have worked it out, but I need to work with it some to see if it is something to add to my workflow.
Thanks for the quick response!
You’re welcome and thanks for the feedback.
Is there any chance to check whether a file is transcluded in Markdown like a backlink? I could not see any details in the document inspector.
No. A transclusion is not a link, neither item nor Wiki, do it doesn’t appear in the Links inspector.
Ok. Would be great if this could be thought of for further releases. As the markdown link via x-file-link is noted as a link maybe this could be achieved too as the transclusion is done via x-file-link.
Development will have to assess this. Cheers!
This will be great =)
Yes, please!
See also: Feature Request: Display items into which a given markdown item has been transcluded
