I’ve been using the Import, OCR, & Delete Script for a while. After recently upgrading to Devonthink 3, I noticed it wasn’t working anymore. I started making changes to the script, but then came across the recommendation in the Take Control Boo to use a smart rule. I’ve got my folder indexed, but I’m wondering how to
Rename the file on import - I’m using the import from iPhone feature in the folder right click menu to bring in items that can go through my ScanSnap, and they all get saved as “Scanned Document.pdf”.
Choose the destination group, which is something I had set up in the old script.
Are these two things possible to do? I’m having trouble figuring it out in the smart rules creation dialog.
For 1, I’d just like to have a dialog come up and type in the name - manually typing it is fine, I just want it to be part of the workflow.
For 2, I’d like to mimic or use the functionality of Select group, as in Preferences > Destination > Select group, which is how things are set up for my ScanSnap right now. I think that’s how I had your script set up, though I might be wrong, and testing it back on DT 2, it’s not working. Here’s what I had:
-- DEVONthink - Import, OCR & Delete.applescript
-- Created by Christian Grunenberg on Fri Jun 18 2010.
-- Copyright (c) 2010-2017. All rights reserved.
on adding folder items to this_folder after receiving added_items
if (count of added_items) is greater than 0 then
tell application id "DNtp" to launch
repeat with theItem in added_items
set thePath to theItem as text
if thePath does not end with ".download:" and thePath does not end with ".crdownload:" then
set lastFileSize to 0
set currentFileSize to 1
repeat while lastFileSize ≠ currentFileSize
delay 0.5
set lastFileSize to currentFileSize
set currentFileSize to size of (info for theItem)
set theRecord to ocr file thePath to incoming group
if exists theRecord then tell application "Finder" to delete theItem
end adding folder items to
Smart rules don’t support user input, they’re supposed to run silently in the background (at least without scripting). However, version 3 includes the same script which can be used in the Finder’s folder actions. Finally, just select Preferences > Import > Destination > Select group and the group selector should be used.
Thanks @cgrunenberg. The script for
DEVONthink - Import, OCR & Delete.scpt
in
~/Library/Scripts/Folder Actions Scripts
seems to be the same script as before installing DT3, even after running install add ons from DT3. Should it have a different app name in the script file? If it still says “DNtp” is this evidence that it’s the old script? The text is exactly the same as what I posted above.
Both versions use this to ensure compatibility of scripts to multiple editions/versions. You could remove the installed folder action scripts and install them again to be sure that the latest one is really used.
So I’ve removed the old scripts, reinstalled the new scripts, checked that the folder action is set up, and restarted my computer for good measure. The script works mostly: I can drop a file in the folder, the folder action runs and grabs the file, I can see Devonthink process it and OCR it, and it appears in Devonthink, but it gets dumped in the global inbox, rather than allowing prompting me for the destination. The select group preference doesn’t seem to be applied. Here’s a screenshot of the settings in Devonthink:
Yes it’s possible, however automated processes like folder actions typically run headlessly with no user intervention.
That being said, this does what you requested but note it will switch to DEVONthink automatically for the rename.
set theName to ""
activate -- DEVONthink is going to need focus so we're explicitly giving it focus.
set currentName to (do shell script "basename " & (quoted form of (POSIX path of (theItem as text))) & " | sed -E 's_(.*)\\..*$_\\1_'")
repeat while theName = "" -- This just safeguards against an empty filename
set theName to text returned of (display dialog "Enter the filename:" default answer (currentName as string)) -- Using the current filename also safeguards against an empty filename
set theRecord to ocr file thePath --to incoming group
set name of theRecord to (theName & ".pdf" as string)
Also note this is using more advanced techniques to cull the current filename as a default filename for the output. There are other methods in pure AppleScript that would take a bit more effort to get the same result.
Thanks @BLUEFROG. I’m having a bit more trouble with this that I’d like to admit. If I replace the tell - try block in the previous script so that it looks like this:
set theName to ""
then adding a file to folder will kick off the script (I see a gear icon in the menu bar), switch to Devonthink, and then stop. Nothing is processed, no name is asked for.
If I run your block as it’s own script, nothing happens. Did I miss a few parts pasting it in?
delay 0.5
set theName to ""
Hey @BLUEFROG, so when I had been doing my testing, I already had DT3 open. But when I don’t have it open, and drop something in the folder, it opens DT2. Is there a way to correct that, other than to delete DT2?
You should not run DEVONthink 2 and 3 on the same account, on the same machine. At a minimum, you should delete DEVONthink 2.x from the /Applications folder and reboot the machine.
