I’m a fairly new user of DT so this is one of those “could use some help to stop me overlooking the obvious” questions…
I constantly find myself “losing” documents in the folder structure.
I usually work in 3-pane view. I’ll be looking at a document and switch to another folder. The upper right pane then shows the contents of that folder, and the lower right pane is empty until I select a new document to view. When I return to the original document using the back button, the upper pane still shows the contents of the folder I switched to, that folder is still selected in the left pane,and I am looking at the original document in the lower right pane with no clue about where it resides. At that point I don’t know how to locate it in the folder structure, except by doing a search.
I have located the Reveal command, but I can’t see that it does anything.
What am I missing?
