I have been using the following script to add the URL from the frontmost Firefox browser window to DT as a web archive, and also to provide notification via Growl that the web archive has been successfully completed:
--Define the Growl parameters
set growlMessage to " was saved to group--> "
set myNotice to "Simple notice"
set myGrowlApp to "Growl Applescripts"
set myTitle to "Save to Devonthink"
--Register this script with Growl using the DTP icon
tell application "GrowlHelperApp"
register as application myGrowlApp all notifications {myNotice} default notifications {myNotice} icon of application "DEVONthink Pro"
if ((application processes whose (name is equal to "firefox-bin")) count) is greater than 0 then
if (count of windows of application "Firefox") is greater than 0 then
tell application "Firefox"
set theURL to «class curl» of window 1
set theTitle to «class pTit» of window 1
activate
with timeout of 120 seconds
set theDestination to display group selector "Destination" buttons {"Cancel", "OK"}
set theArchive to create record with {name:theTitle, type:html, URL:theURL} in theDestination
set data of theArchive to download web archive from theURL
end timeout
activate
--Growl Notification of success
set theGroup to (name of theDestination as string)
notify with name myNotice title myTitle description theTitle & growlMessage & theGroup application name myGrowlApp
else
notify with name myNotice title myTitle description "Clipping failed. Firefox is not running!" application name myGrowlApp
else
I was hoping someone could help me modify this script so that I could pre-define a specific Destination/Group which web archives should always be captured to, and then have things setup so that the web archive would be added to DT in the backgroud, thereby allowing me to continue browsing in Firefox without having to switch back to it from DT…
Any suggestions would be greatly appreciated… Thanks!
