Hi,
I wanted to create a text style script to make the font in question red. What are the reference numbers for a good red?
Also, I wanted to make a block text style script, something indented 5 spaces or half an inch. Thanx in advance for the assistance.
Did you have a look at the scripts in the folder ~/Library/Application Support/DEVONthink Pro 2/Scripts/Format?
Hi,
Yes I did have a look through those. I think I have the basic idea. Any reference sites indicating the script elements for indenting, and various standard colors? I appreciate any help. Thanx.
Colors are RGB values and range from 0 to 65535. Red is for example {65535, 0, 0}. But rulers are not accessible via AppleScript.
Ok, I’ll give those numbers a shot. Thanx
