Help with WebDav Sync Setup...
Hi,
could someone please have a look at my settings for webDav Sync (Attachments). Sync doesn`t work. In the log it says “Konnte die Ablagestruktur nicht verifizieren (Verbindung fehlgeschlagen)”. WebDav in general is working on my NAS. Did I made a mistake in the Path Syntax?
best regards an thanks!
When I tried to set things up, I had trouble getting WebDAV over HTTPS to work. I turned it off on my NAS and switched the port number to 5005. I put in the IP of my NAS for server address. Assuming the path is correct, that should work.
I don’t do German the best, but I got a similar message - Could not verify store structure (authentication failed). The message went away when I took the above steps.
