Hi,
Can anyone explain how the iCloud sync mechanism works?
At the moment I have a 50mb database stored in my documents folder on my macbook. I’ve selected the sync via icloud option and the files have been synced there. I’ve also got a mac mini and I have been to the sync window, put in the database name and downloaded the synced database. So now both Macbook and Macmini have the same 50mb database stored in the Documents folder for each of them.
However, I noticed that if I go to iCloud Drive from finder then there is a devonthink folder. Presumably this contains the syncing files? Anyway, this folder is also 50mb. Does this mean that I now have a copy of the whole database in my Documents folder PLUS a second copy in the iCloud Drive folder? I.e., Instead of there just being a 50mb local copy my machine now effectively has the 50mb local copy PLUS the iCloud Drive copy (which also appears to be local) used for syncing?
I’m confused, I don’t really want to be wasting space on the macbook with two copies of the database. Can anyone explain how this mechanism works?
Apologies support team if you are reading this (I emailed to ask the same question before I found the forum).
Thanks.
