I have 8 databases (incl.Inbox) in frequent use and I synced them through one syncstore.
Now the sync data of the Inboxes on teh diffeernt devices became corrupted and via setting up a new syncstore the sync process of the Inboxes works well again.
My questions now are:
Should I migrate the other databases to the new syncstore?
Or is it better to have separate syncstores?
Maybe even one syncstore per database?
Maybe with the one-syncstore-per-database solution I could have avoided the corruption in the Inboxes’ syncstore?
My understanding is it preferable that a database should have more than one sync store (note that in this context Bonjour is not a sync store). But there is no requirement for every database to use the same sync, or to explicitly use a different sync.
A sync store can synchronize an unlimited number of databases, therefore you could e.g. use different sync stores for your personal and professional databases (and share the second one with your team).
That’s basically correct, you shouldn’t synchronize the same set of databases to the same set of devices/computers using multiple sync stores. This is redundant, slows things down, causes more network traffic and in the worst case, due to race conditions depending on preferences and actions, might create unnecessary duplicates.
But you could e.g. do this:
Sync Store Personal (used by your personal devices/computers only)
– Database 1
– Database 2
Sync Store Professional (used by one of your devices/computers plus the devices/computers of your colleagues)
– Database 1
– Database 2
This means that one central hub can synchronize databases via multiple sync stores.
But Im still unsure what to do: I have moved the Inbox to a new sync store due to corrupting - should I now move all the other databases to this new sync store and delete the old sync store completely? Or shouldn’t it matter?
Can a local sync store be uploaded to Dropbox for example, and then the dropbox store be accessed w DTTG?
I’m just looking for ways to get my Mac to quit tying up the WAN (I have slow internet).
my other “backup” jobs (I know sync != backup) run overnight but I don’t know how I would implement this w DT.
Is there some other way to set up DT so it can function as bonjour by day and remote sync by night? Would be cool if bonjour could interrupt remote sync connections.
No this is not possible as DEVONthink To Go can’t access the files inside Dropbox.
No, neither of these is possible at this time either.
Hi. The answer to this question is probably “obviously yes”, but is the reason why the list of databases in a particular sync store (dropbox) takes a long time to load is because of the number of separate databases in that sync store? Is this a reason to divide databases across different sync stores? Sometimes I give up waiting for the list to load on my iPad, but I have about 40 separate databases in that sync store.
Close…
Each database has its own directory within a sync store. The store is the .dtCloud file. The databases are stored in directories within the sync store.
Your situation is highly unusual but yes, it could be a contributing factor. However, you can’t discount the other options @rmschne mentioned, e.g., the network quality, the reachability of the remote server, etc.
What is your use case to have so many database and all syncing to one sync store?
