Devon Think 2.0 is great.
great tool for searching my files and email for what i’m looking for.
but
how to set a script so that it automatically (daily) imports new email messages and indexes the folders so it keeps up to date?
is there a way to automate this?
even though i can do it manually each time, an automated solution would be ideal
thanks
Prem
That’s not yet possible but we’re working on a solution, see viewtopic.php?f=7&t=10064
You could either use File > Synchronize or attach the “Synchronize.scpt” (see Extras > Scripts > Examples on disk image) to the groups.
thanks for the quick reply! i hope you manage to work an email solution for entourage… though don’t spend too much time on a big solution given the new mac outlook coming out at end of year! - an automated script to import with current method would be sufficient
and for folders i’ll see how the adding script to folder works!
thanks
Prem
