Most of the time I want to capture a website as PDF as seen on screen, but not in the print view. Is this possible with Devonthink?
Not yet but the next beta will support this.
Oh, this is wonderful. Thanks for the reply.
With the next version out: I can’t find anything new?
Capture a web page as PDF paginated uses the print stylesheet, capture it as PDF unpaginated uses the screen stylesheet.
I only found it in the bookmarklet, but not in the Devonthink application itself? How do I differentiate between non-/paginate mode there (for converting bookmarks into PDFs etc.)?
Btw: Imho the ‘Capture as …’ functionality should be exposed as normal menu item too.
