In writing a script to import Mail messages as rich text (viewtopic.php?f=4&t=8203), I discovered that
create record in ""
starts the same useful pane for choosing a destination group that is opened by the “Add to Devonthink Pro Office” menu item in Mail and by other DTPO import actions.
-Steve
That’s interesting… It doesn’t seem to work for me… It just creates the record in the incoming group of my default front database.
I use the “display group selector” command all the time and it seems to work just great for selecting a group destination.
Chris
I agree that "“display group selector” is the better way to go. I think this worked only because I checked “Select group” as my default Destination in the DTP’s Import preference pane.
