On one of my databases i got the following in the logs (in the Trash!):
So I ran Verify & Repair, but it could not repair the error:
What’s the best way to fix this?
The best way is to start by reading page 173 of the DEVONthink manual, which explains in detail what the best way is
Thanks a lot for the pointer.
Will check it out.
You’re welcome - if it doesn’t work out, please report back for more help
Wow, just read that you only need to right click on the offending item in the log window and solve the problem as you desire. - That’s really cool!
As always: DEVONthink rocks!
And: “The DEVONthink Manual” rocks.
