Hallo,
I couldn’t find a deinstaller-script. How can I remove DEVONthink from my machine? Just dragging the main-Application into trash would not be enough, isnt it?
Hallo,
Uninstall directions are provided in online help. Choose Help, select the application’s Help file and search for ‘uninstall’’. Directions will differ depending on the DEVONthink edition that had been installed.
