I am rounding up all my old databases before moving to Devonthink 4 and I came across a .dtBase folder that must have been one of my first Devonthink databases that I never updgraded to .dtBase2 . It shows as a folder and I cannot open it with DT3 so how do I upgrade it?
Welcome @playerfour
DEVONthink 1.x was before my time so I had no database to work with. But development let me know those old .dtBase files can’t be opened in the modern versions of DEVONthink. Sorry for the poor guess.
Assuming DT2 could update DT1 databases, you could create a virtual machine of the highest macOS version supported in DT2, install DT2 in it, and then update that DB into DT2. If I remember well, once in DT2 you can directly open in DT4 the database and it will go to the current version. If not, well then install DT3, open/import the updated db in the virtual machine, and go so on.
I had to do similar stuff under other Windows software.
All versions up to 3.9.6 are able to convert the old format. See https://www.devontechnologies.com/download/legacy
