I have DTPO 2.9.16 and would like to upgrade to 2.10 for the iCloud syncing. When I go to Check for Updates nothing happens.
Is 2.10 available for DTPO or just for DT? If it is available, how do I upgrade?
TIA
Martin
TIA
Martin
Please download a new installer from here and replace your current version: devontechnologies.com/redir … d=download
Do not run a third-party uninstaller. If your browser isn’t set to open safe downloaded files, just double-click the ZIP file to decompress it. Then double-click the disk image to open it, and drag and drop the application into the /Applications folder, allowing it to overwrite the old version when you’re prompted.
(There is no danger to your data when you do this. (1) Your data is not stored in the application, and (2) we would not give you instructions that would jeopardize your data.)
Thanks for the answer. I appreciate it!
You’re welcome.
