Just wondering if anyone else is having trouble creating links to Bookends refs in DTO Pro.
I followed the BE instructions for creating a link. This works in other applications – I drag the Bookend reference to the other app, and a link appears. But in DT the result is plain text. Is there some preference setting that I need to change?
If I’m dragging references from BE’s main window to TextEdit or DEVONthink, then plain text is inserted in both cases.
To create links one has to drag the ID from the reference window or drag a reference from the main window while pressing Command and Option modifier keys.
I don’t know if there are any other possibilities.
Thanks, the second of these two options does indeed work for me. With the former, it never does – if I try to drag the ID number, the response is as if I am trying to drag the whole window about.
However, that’s not a DT problem, and anyway, as I said, the second method works.
