I use 2 monitors with DPO on one (the secondary) so the menu commands are on the other monitor. I often search through documents for terms and, while I have defined keystrokes for the “Next highlight” command, they are either unweildy or don’t work after a time.
A pre defined icon that could be included in a custom toolbar would be brilliant.
Just want to be clear: Are you asking about a ‘physical’ button in a toolbar, that can be clicked to jump through all the ‘found’ items inside a document, from a Search?
Yes, that is exactly what I am looking for. I have the Next icon in my Toolbar but that seems to only move from the first highlighted term in one document to the next.
