I’d like to import some notes from EVERNOTE, but when I do the procedure (FILE>IMPORT>NOTES FROM EVERNOTE). I get a log with “Time,” “File/Action. -Notes from Evernote” and under “Info” it says “No notebooks.”
I have EVERNOTE open during this procedure, but no luck.
I’ve learned that the newest Evernote version does not allow for the import method I describe above. However, you can export and then import NOTEBOOKS to DEVONthink – I had success doing that, but still have to check all the files that came in to see if any problems were introduced.
You’re welcome. I’m around here a bit, but I’ve not come across anybody describing problems following ENEX export from EN and import to DT, so I’m hopeful you will have succeeded without any further ado.
