Scans from my ScanSnap iX500 are going to the global inbox even though “Select group” is selected in Preferences > Import. Following the scan, and after I rename the file, the destination window pops up and I’m able to select the group where I want the file to go. But it goes to the global Inbox instead. It seemed that this worked correctly when I first started using DT3. I’m running DEVONthink Edition 3.0beta2 on macOS High Sierra 10.13.6.
OCR is being done by DT3.
