Is there a way to export tags, but without the documents that are tagged by those tags? In other words is there a way to export only the tags as tags, and import them into another DTP file?
I ask because I have a mega central DTP database, but I also gather data into some smaller databases, and tag that data before exporting it into the central database. I have set up a pretty complex hierarchy of nested tags that acts as a mega index to my content. When I am tagging files in one of my smaller databases it would be useful to have the same hierarchy of tags in that file so that I don’t unnecessarily duplicate tags, or have to refer backwards and forwards between databases to recall what tags I used.
If there IS a way to export and import tags, it would be great to know it. If not, is it something you could add to a future release.
You could use this script to duplicate a hierarchy without its documents:
-- Duplicate hierarchy
set theNum to my duplicateGroups(the selection, incoming group of current database, " copy")
if theNum is 0 then error "Please select one or more groups."
on duplicateGroups(theRecords, theDestination, theSuffix)
local theRecord, theName, theCopy, theNum
set theNum to 0
if type of theRecord is group then
set theName to ((name of theRecord) as string) & theSuffix
set theCopy to create record with {name:theName, type:group} in theDestination
set theNum to theNum + (my duplicateGroups(children of theRecord, theCopy, "")) + 1
return theNum
end duplicateGroups
Just select the “Tags” group, run the script, then move the subgroups of Inbox > Tags Copy to the “Tags” group of the destination database.
Hi. I am trying to duplicate an extensive list of tags from one database to another. I have amended the application id in the script above to accommodate DTPro3. - amended script is
set theNum to 0
return theNum
end duplicateGroups
I then selected the Tag group of the database I want to copy in the Globals area of the side bar, run the script and get the DT dialogue box “Please select one or more groups”. Think I have already done that, and selecting the tag group again , clicking OK in the dialogue box , appears to terminate the script.i.e. nothing happens. I am new to scripts and DT, perhaps I am missing something. Any help would be appreciated. Thanks
I would like to copy a pretty large tag structure. In DTPro3, this script still works great for copying folder structures.
However, when I try to use it to copy tags, I get an error: “Please select one or more groups” even whenI have selected tags.
The above script should only create groups. A screenshot showing the selection before running the script and a screenshot of the result would be useful. Thanks!
