Is there any way to import results frojm DA to DT as web archives rather than as HTML. Failing that, is there a way to batch convert HTML records to Web Archives?
I am find HTML records slow to load in comparison to Web Archives.
Under “Data | Add to DEVONthink”, you’ll find an option for Web Archive.
If you’d like this to become the default behavior for Cmd-I, just go to your Keyboard & Mouse Preference Pane and select the Keyboard Shortcuts pane. Press the little + icon to the lower left, select DEVONagent as your application, and for the Menu Title enter “Web Archive” (exactly like that). Make the shortcut be Cmd-I.
Now when you press Cmd-I in DEVONagent, it will import a web archive into your DEVONthink instead of an HTML page.
Now, what I’d really like is an option to batch import the results of a query as webarchives instead of as HTML pages…
John
Sorry, I should have specified that I was looking for the batch archive fashion. I often get results into the hundreds and I can’t do them all one at a time.
Do you think this could be scripted somehow?
The following script downloads web archives for all results of the frontmost search window and adds them to DEVONthink Pro. But this might take “some” time.
tell application "DEVONagent"
activate
if not (exists search window 1) then error "No search window is open."
set theSearch to search window 1
if searching of theSearch then error "Search is not yet complete."
set theResults to search results of theSearch
if (count of theResults) is 0 then error "No search results."
if not (exists current database) then error "Please open a database before using this script!"
show progress indicator "Downloading..." steps (count of theResults) with cancel button
repeat with theResult in theResults
set this_name to title of theResult
step progress indicator this_name
if cancelled progress then exit repeat
set this_URL to URL of theResult
if exists date of theResult then
set this_date to date of theResult
else
set this_date to missing value
set theData to download web archive from this_URL
set theArchive to create record with {name:this_name, URL:this_URL, type:html, date:this_date}
set data of theArchive to theData
hide progress indicator
display alert "DEVONagent" message error_message as warning
on error number error_number
if error_number is -1708 then display dialog error_message buttons {"OK"} default button 1
