Is there a way to index my Evernote documents in DEVONsphere searches?
Thank you.
Thank you.
You could try to add Evernote’s metadata cache (see ~/Library/Caches/Metadata) to the locations.
Adding the folder com.evernote.Evernote or -records (in ~/Library/Caches/Metadata) does not work. No notes found.
“Adding the folder com.evernote.Evernote or -records (in ~/Library/Caches/Metadata) does not work. No notes found.”
This was my outcome as well.
